Build 79 Aussie BJ55 build
i.php
i.php
i.php
i.php
uuggh pin holes :edit: fish eyes apparently.. caused by contaminants on the surface.. .. i'll likely seal up the booth completely before doing the roof.
i.php
a bit heavy where i couldn't see.. well at least the drain works!
i.php
Make sure you’re using a fresh air hose with dryers too
yup. empty the tank and water seperator at the tank before starting. inline seperator at the tank. got a disposible one ill add to the gun though.
got about 2 pots of paint or 3-4 coats on the roof this morning.. and only 1 tiny bug! Pretty happy with the result so far..
i.php
i.php
i.php
Yay for PPE.. and a booth! there was quite a bit of overspray on everything so it was good to be contained within that space.. Those are fresh filters on the respirator too.
i.php
i.php
i.php
It's been a busy few days.. It's school holidays here and the wife had organized a 3 night getaway with her mum and the 3 kids so I could get some work done on the pig without interruptions... The solid block of time on the pig meant I could get some extra hands in to help too.
so I took friday off work and got the interior etch primed and high build primer down ready for paint:
i.php
My mate Ben went through and seam sealed it yesterday:
i.php
Gary fitted the AC pump and idler, then helped modify the factory 1FZ power steering cooling lines to fit up to the 15BF. They still need a bit more love with the front bib on but they are close.
i.php
I got the starter on:
i.php
Dummy fit the snorkle.. I think It'll fit with a bit of heat gun massaging:
i.php
And I modified the trans tunnel cover to suit the gearbox/4wd shifter:
i.php
i.php
A heap of other stuff was done too like strip the hardware from all the doors, fender and hood ready to strip the paint.. rear diff brake stuff put back on, etc and a few other things worked through.
I'm busting a nut to try and get the interior painted so I'm ready to get the windscreen glass installed.. the weather this weekend is cold and wet and the best day on the long range forecast is tuesday at this stage so fingers crossed I can knock it out then.
The next big ticket item for me is to figure out how to fab up brackets for the radiator and intercooler setup up front..
Also going to have to build 1 airbox out of two, fab a battery tray, etc.
The big kicker is getting the interior painted cos that means I can start putting the dash, pedal box, steering all together for the last time.. Also on my list is to check pinion flanges match what I'll be running with the 4.56's, and finding drive shaft uni's to fit, then measuring for driveshafts, and ordering seatbelts too...
Having fun mixing and matching driveshafts so I can get the driveshafts shortened and they are running the correct flanges for now on 4.11's and then again when I swap in the 4.56 air locked diff centers..
i.php
I think these are the drive shafts from the 80 and BJ73.. I need to dig around some more and see if I can find the 55 drive shafts.. they may mean I avoid having to bust uni joint flanges off one to fit on the other..
i.php
i.php
i.php
i.php
i.php
i.php
The reflection in the paint on the roof is crazy!
Even though my contribution was small I was all too happy to help with this epic build. It was great seeing it in person. Thanks for feeding me as well!
Driveshafts dropped off for shortening and new clutch slave installed yesterday.. Prepped ready to lay down some paint today on the interior as its my last window before windscreen install with the weather looking favourable.
