75 series fuel sender wiring
Just about finished my 12ht conversion, gearbox replacement and t case rebuild. During the process the removed my fuel tank to clean it and add a return line. The previous owner had cut the plug off the fuel sender unit for some reason and had poked the bare wires into the wiring loom plug. I was stupid enough not mark the plug on the loom that it was poked into. I know that it goes into a black round connector from the sensor but I don't know where it goes after that So if anyone knows where the fuel sender plugs in on a 89 hj75 or could have a look on their rig that would be great a photo would be even better
Cheers
Should intro myself as well, got a hj75 which I have just about completed a 12ht conversion on, plans for the future include a 50mm lift, winch, overhead console,33 inch tires and dual batteries, will attach photos at a later date
Well after three hours of looking I found out why I couldn't find it, turns out cause I used the gearbox out of a 60 series that the loom that came with the box is exactly the same as my old loom apart from the fact it has no fuel plug, not to worry have just wired it directly back the first point I could find the yellow and red, thanks anyway aussie25, I've been using mud a lot lately so decided to join, heaps of valuable info on here
