What year is the manifold?
How much for the:
Thanks for your time.
- '73 below license plate light $5
- windshield hood bumper SOLD
- the 4 lamp gaskets (81734-60030 & 81744-60030) SEE BELOW
- the front turn signal lenses (81511-60140) SEE BELOW
- which "Light gaskets and lenses $20 for all of it?" were you talking about? ALL OF THE NEW GASKETS AND LENSES
- are the used rear reflectors in picture #3 Toyota? Will you sell separately from the assembly? SOLD
- Any side marker amber lights left? SOLD PENDING ZEPHYR
- On the '72 steering wheel, is that grime on the wheel or dry rot? HAS SEVERAL CRACKS AROUND THE BASE AND IT HAS BUILD UP GRIME.
Interested in the:
Turn signal indicator New 72 style column $60 - should be the two pieces, upper and lower
Heater 'H' knob
Thanks!
Sounds good let me see what flat rate box they fit in $80 shipped for all of it should work.
Yes it is. Thanks.
Amber lights are SOLD but if you want everything else pm me an address so I can check into shipping. The steering wheel is going to require a different boxExcellent. Interested in the above other than what you put as "sold". Let me know on the amber lights at your earliest convenience.
I would like the 72 steering wheel if still available, do you also have the front turn signal lens?
Is that 73 rear heater still available?
Yes I do not have the motor portion of it tho.
(Square bottom). and those used reflectors?
Sorry sold
Rear 73 harness?
Pretty sure I have an entire harness for a 73 I’ll lay it out today to double check
Exhaust manifold for the 1f?
Yes I still have it.
Pm coming. Maybe you can shoot me pics via text. ThanksLet me know if you have any more questions
All of those are sold sorryLooking for both front and rear axle brake line T's (the one that the soft line connects to the hard lines T) and if you still have the rear side tub Red marker lights
