My family and I recently completed a resto on my 1971 FJ40. The windshield was reinstalled after the new paint... everything is fine until I reached 50 mph and the windshield popped out. A local glass shop reinstalled the glass and it happened again. Before I ask the question- yes, I searched the forum for install and frankly found some confusing information about installing it. One paragraph states install the gasket around the glass first and the other states install the gasket around the frame first and then place the glass in the gasket (on the frame). Which is correct?
Some additional information:
- The windshield is original. It measures 15 1/2" for height. Lenghth was hard to measure due to the position of the popped out windshield in the window frame. I never had an issue before it was removed and re-installed.
- The gasket is SOR for 65-74. I called to double check and it is the right part.
- My Cousin had the exact same issue happen with a pop-out at 70 mph. He insists the gasket first on the frame install is correct having experienced the issue. He has not had an issue since.
- The glass tech (whom I called after the pop-out) insists- based on previous FJ40 windshield installs that gasket around the glass first, install in the frame is correct. He will reinstall again, but is hestiant about the gasket on the frame first install.
So which is it? After two pop-outs I want something that works.
maybe try glueing the crap out of it?
