70 series wheel fit an fj60
Looking for steelies that would fit the 60 series ideally without spacers.
I like the OEM look, but am looking for a 16x6, 16x7, 16x?.
Can someone let me know if this is accurate?
Thanks!
Maybe another way to put it. Will the 70 series vehicle (what years) steel wheel fit the fj60? From reading the 70 series wheel seem to be in size 16x6. Is that right?
Any rim you can bolt onto a FJ60 you can bolt onto a 70 as the brakes in most cases are the same
The question is what offset your running. After market rims you'll need some offset to clear the brakes , I've brought Cruisers in the past and found muppets have run washers in behind the rim to clear things like calipers. Just check you'll have the clearances needed
But as for stud pattern . 40/60/70/80 are the same
Hilux will also fit but the offset is about 10mm different
