- Location
- United States
Hey all,
I've had it on craigslist off and on for a while and have had some interest but no sale yet. I feel I have a pretty reasonable price
on it but any feedback is welcomed. I am asking $2500. I have put more than that into it since I bought it. I also have a FJ40 and
a FJ60 so one has to go...
Flickr: offroadrunner1's Photostream
This LandCruiser needs a good home. I started to make it a reliable camping/expedition rig but need someone else to take over.
Come see it and drive it.
Cruiser has 72 F motor, 4sp trans, rebuilt carb,
rebuilt steering box, replaced tie rod ends/relay rod end, drag link.
Brakes changed to dual circuit set up(ready for your disk brakes)
rebuilt wheel cylinders
rebuilt power booster (FJ60)
rebuilt master cylinder (FJ60)
adjustable proportioning valve
extended front brake lines
Parking brake
used drum/ pads
output bearings
new sway bar bushings, new motor mounts
Rear axle overhaul, seals/bearings
Add-a-leaf 1.5" lift
Back power window works
Sunroof
Body is in above average condition for a FJ55. There is some rust in the roof panel of the truck, as well as under the rocker panels.
There are a couple of rust holes in the front floor pan.
The front doors are sagging a bit on their hinges, the hinges need to be drilled for new pins or buy already rebuilt ones. Front doors
also need regulators to close tight.
Exhaust manifold leaks. Gasket needs to be replaced.
Weatherstripping is old and cracked and will need to be replaced at some point.
I guess I'll let the pictures do the rest of the talking for themselves
Parking brake
used drum/ pads
output bearings
Sunroof
