No. No place to put the banana.
Hi, all. I was referred to this thread by @Old Red from a question in my thread in the 40 tech area. After poking around a bit here in the 25 area, looks like I may find more info on mine here, might see about having my thread moved here.
Related to this thread, my 40 shows on the data plate as being a ‘64, with a frame number beginning with a 3 indicating 1963 build. For comparison, mine is also an FST, with PTO winch in bandaid color. Frame 3-FJ40-19056, originally sold in Oregon in November 1963. Definitely seems to be an early ‘64 by all the physical details. Same as the subject truck here. I will be watching this thread with interest.
Thats interesting, Mark. I looked but didn’t see the date code on the carb. I’ve been guessing a mid-summer build date, maybe it was earlier than that.If I remember correctly, the build date on your carburetor was from the beginning of ‘63.
@middlecalfThanks @middlecalf
The "V" designates a "Hard Top" model.
63cruiser - Your rig looks awesome in those neighborhood pics of the classic houses.
The vader light is a single wire, self-grounding light. In mine, it was connected to a cheap aftermarket pull switch in the dash. Other threads make it appear that there should have been a larger pull switch for it, possibly in the same spot as mine and that should have a black knob that may or may not be marked “ROOM”.
Of course, mine is a 40L, not an LV. I’m assuming the L denotes LHD, but what is the V for?
Good confirmation. That’s how it should work if it was connected directly to the M terminal of the headlight switch as the wiring diagram shows.can't claim to be an expert, but never seen the switch marked when it was separate. my 62 has the vader light off the headlight switch and it's on with headlights and marker lights (both turns to the left), but off when off and to the right (rear lighting)
can't remember who, but someone owns the rig three numbers older than annie and his is a 1962 titled as a 1962. therefore, his rig was sold to a dealer before annie, even though anni is older.
