For Sale 62Series Diesel Land cruiser
OPEN TO REASONABLE OFFERS
NO TRADES
1989 Fj62 with 1986 Hj60 motor
6cyl diesel +auto 340xxx kms
24volt
winch, bumper, snorkel
new 35in tires (MT/r)
heavy duty suspension, Sprung over axle (+cnT)
5.29 gears, rear locker
DD until last winter
lots of spare parts
full maintenance records
truck near port credit mississauga
still registered as a gasser(can change at request; no problems)
email more info
tdc420 @ hotmail . com
pm for phone#
ASKING 9500$cdn cash or gold
more then anything i want this rig to go to a good home
see my rotm for all details and pictures
no chat plz
over 40000 kms on the 2h since the swap and 5000+ kms on soa
my buddy and brother rented a garage and started a shop ( Defiant 4wd). my buddy got sick too and bought a mercedes 300sd for his sas 4runner and we raced to see would would be done the swap first :D
dont make it sound easy or anything... :flipoff2:
i'd also like to point out while talking about the 4runner you said "we made a custom plate to mate the engine tranny" like you were talking about making a peanut butter and jelly sandwich.
is there anyway to register it as the 86 model so that it could be imported to the states? since it looks like there are just as many parts out of that vehicle as the 89 you started with.. :hhmm:
thats a sweet rig, wish i could buy it.
i went ahead and googled it for the states. thats $9908.21 USD or roughly 5.99444725 ounces of gold...
Thanks zrheard for the compliments
its a canadian fj62, was also available in the US, so i dont think theres any restriction import that. also still being registered as a gasser might help with import, but i can change the registration to diesel no problem. i dont believe i can change the year of the truck, thought i still have all the VIN plates from the donor vehicle...
as for the mercedes 4runner, we took out the wax crayons to measure with a string(then later a tape) and salvaged 1/4in plate steel and cut it with a torch. sound simple, but its a bit more complex when its in front of you and in your hands. I didnt actually do very much helping with the plate. we had a good time: mercedes & toyota sandwich
ps, only 6 gold coins eh?
another thing to consider: i have a parts 62 and could easily swap the axles(+4.11s) under my truck, but then the 35's dont fit, you loose the 5.29's and the rear locker. it would look like this
Hj62 Land Cruiser
2H 6 Cylinder N/A 24volt with A440 Automatic Transmission (340000kms)
Suspension/Axles:
-Dakar Old Man Emu extra heavy duty (2.5in lift)
-7 leafs in the front 9 in the rear
-Anti-inversion Shackles
-Greaseable Shackle Pins
-Sprung over axle(SOA) (5in lift)
-Cut & Turned (CnT)
-V6 4Runner calipers
-5.29 Gears
-Rear Lock-Rite Locker
-Marlin Hy-Steer
-35x12.5r15 Wrangler MT/r Kevlars
-15x10 steel rims
-custom rear double cardan drive shaft
Needs: Shocks, shock frame towers and shock axle tabs, 1 rear axle bearing, front ujoint
Motor:
-recent new Toyota oil pan
-recent Toyota glow plugs
-recent new Toyota muffler & tailpipe
-recent new Toyota injectors(+ Toyota fuel filter)
-Safari snorkel(+ Toyota air filter)
-New Priming pump (Denso)
-2 New batteries (900cca each +10year warranty)
-New Toyota fuel tank
Needs: Speedometer cable, oil change
[and a standard transmission]
Armour:
-Class V Hitch (+trailer light harness)
-Front Bumper 1/4in boxed steel
-Warn 18000lbs Winch (+new remote)(less then a dozen pulls old)
Could use: a Spare Tire Carrier
Body:
-Has dents and scratches from off-roading, nothing major. This truck was in Ontario all its life and is starting to get some rust. The undercarriage been oil sprayed and the frame is in solid condition. The rockers ‘had’ surface rust which was grinded and painted a couple years ago. On one side Rocker Guard (bed-liner style) the other POR15. The rockers and bottom of the doors were painted olive green. The passenger fender has a hole at the bottom and the snorkel hole is a hack-job. The upper tailgate is starting to rust bad need the handle. There is a bad rust on the driver side windshield L. Overall I would give the body a 6.5 out of 10
Needs: Passenger Fender and Upper tailgate or repair
Interior:
- Overall clean, no dash cracks, there is a tiny rip in the headliner near the tailgate, original 4wd instruction stickers, Toyota jack & tools. Driver seat has been replaced with a used passenger seat of good condition, only a small cigarette burn. The radio & speakers are not hooked up. 7 out of 10
Needs: Radio, horn and parking brake adjustments
Spare Parts: a big pile
little topper, just moved to alberta. truck is near toronto
still open to reasonable offers
and feedback on price & condition wise
(before the snorkel)
