62 fuse schematic label request
Wile E Coyote
Out in the streets, they call it murder!
Western AZ
The fuse box cover for my 62 broke into pieces and one half is MIA. I have a replacement cover from a 60 that I'll color match to the charcoal/graphite gray (non-matching light gray at this point) but the paper fuse schematic pasted inside is no longer accurate.
Anyone have a good hi-res pic of said label that I could print?
You might be able to find a used 62 fuse box door for pretty cheap. Then it would match perfectly and the label would be perfect too.
[Edit] Well I just checked at SOR. Used. $110 ouch.
If someone has a photo of the '62 label and the dimensions, I could whip out a hi-res copy in Adobe Illustrator pretty quick.
going clockwise around
6 3/4 top
1 right side
4 1/2 bottom
1/2 drop
2 1/2 bottom
1 1/2 left side
Ooh, very purty. Many thanks, amigo!
Outstanding! Thanks to OS as well for the "more gooder" res labels! I'll print then maybe laminate it for longevity.
^^^This - Thank you @Output Shaft - just got a replacement cover and figured the schematic would come with it. :cheers:
  • Like
Reactions: OSS
Post revival… anyone have a similar high resolution picture for a 60?
TIA
X2, I need this for my 60. Does anyone have that? Perhaps you could post a pic of your '60 paper if still available @Wile E Coyote?
Thank you Output Shaft. I got a new cover and was referred to this post when I contacted the seller about the diagram.
  • Like
Reactions: OSS
