60 vs. 62 Fender Question
I picked up a couple of reproduction fenders from Marv at Spector a while back. He implied that you would have to add a hole for and extra screw to mount them on the 62, but other than that they would be a direct fit. I've never put them on to verify it.
That is good to hear.
the G models dont have the vent. I know cuz I nabbed one and there is no hole for it. I also had to drill a couple of holes on the inner fender and the headlight window holes dont match up between a 60 and 62.
Is the G model the one overseas with the little reflector or light where the vent goes on the U.S. version? As far as drilling those holes goes...it is relatively self-explanatory on where/how to do it?
Thanks.
Thanks.
its not a hole to drill. if you unscrew your vents you will see the hole I'm talking about. on the G model there is no hole. You would probably need to use a torch or saber saw to cut it out. It would be easy to do but I'm to lazy to do it to my own right now. If you want to have some real fun, try to fit an older 60 door that doesnt have the provisions for power windows. Talk about booty fab.
