60 Headlight Covers(Reduced Price)
Here's a small run of a new design I came up with. Material is double 16ga steel with 16ga wire sammiched between. I wanted to come up with an easy no-hole drill install method so the covers are attached with screws and quick nuts to the outer plastic headlight housing. Quick nuts grab the inner diameter of the flange on the plastic housing. Installation is pretty simple but it is best to remove the plastic headlight housing, then re-install together. Of course to do this, you will have to also remove the front grille. I went ahead and blacked out everything while I was in there with paint. You don't need to mess with the headlight itself tho. I built a set for myself and they turned out good so this small lot is still up for improvements so let me know what you think. I have 5 pair, priced $40/pair shipped US or within reason. Includes mounting hardware and installation instructions. PM me if interested.
