I took my 60 to a local toyota shop who has a good rep here. It hasn't been running that well lately and I am not sure what to do. It does burn oil and has almost 200k miles on it. He did a couple of test on the engine, first was a compression test, he said they all had compression from 150 to 155,158 range. He then said that there was a head gasket leak and that the valve guide seals are bad. He said to do this would be around $1500. He said that would include taking the head to a machine shop. I have been wanting to get my carb rebuilt and he said he would do that at the same time. So, all of this work for around 2k, ouch. He said other then that everything looked good.
My question is should I put $2k into it or should I use that money to put a 350 in. I don't mind driving slow, sometimes I think it would be nice to have more power but not that often.
If I do have this work done, is there anything else I should do?
I recently put a new p/s pump, water pump, and fan clutch it if that changes anything.
Sean
Sean
