I would like to know if anyone has a definitive answer whether the fj62 fr. axle has a higher pinion angle than the '60. It has been my understanding that their was a slight advantage to the '62...? (aside from width)
The pinion angle on the 62 housing is a bit more favorable. The width is the same as a 60. If you are trying to do a spring over without a cut and turn, there is a slight advantage to using a 62 housing.
The real advantage of a 62 housing is that it is trussed from the factory and theoretically more resistant to bending.
Favorable as in it's pointed more towards the t'case?
Right-a few more degrees rotated up, relative to the spring perch and knuckle angle. Kind of like a partial cut and turn. I have a 62 housing in the garage I could take a picture of, but without a comparison, it wouldn't mean much.
