- Location
- United States
From merging my 60 and a 62, I've got a bunch of stuff left over. Most all of it is interior and body parts; I don't have much in the way of mechanicals. Prices/pics below; all prices OBO. Not looking to make a killing; just can't justify throwing most of this stuff away. Shipping isn't factored into any of the prices, but I'll get it to you as cheap as I can.
Will consider trades for the few things I still need:
Check valves for headlight washers.
I'll take Paypal (don_at_sauceboxcreative.com), checks, pesos, whatever. PP preferred.
I don't have the silver star (as I should
), so email will take priority. Address above.
Front (Grey) FJ62 Carpet: $35. Pretty dirty (dishsoap or degreaser + pressure washer always worked for me), but completely intact. No rips, no broken plastic bits on the sides, etc. You can see the sunfading over the trans hump.
Middle (Grey) FJ60 Carpet: $35. Cleaner, some light staining. Footwell area somewhat worn, plastic bits on sides intact.
FJ60 Sun Visors. They look their age. No rips or stains, though they could use a cleaning. The passenger side mount has a crack (pictured), but it still works fine. $15 takes the pair.
Misc. FJ60 Interior Parts. SOLD - Ashtray in good shape - $5. Grey fuse panel cover in good shape - $10. SOLD - Rear view mirror has good glass, but scratches/etc. on the back - $5. Dirty parking brake boot in otherwise good shape (no rips/tears, etc.) - $2. Washer bag + pump, unknown if the pump works (fairly sure it does) - $1.
FJ60 Front Seatbelts (Grey) - $30. Retractors work, no major stains/wear. Driver's side (top left) buckle is boogered a little bit. Comes with pillar caps. Does not come with the receiver end(s).
SOLD - FJ60/2 rear seatbelts (retracting pair only): $30. These are from the '85, and they're post-recall. They work (as well as any of them do, anyway). Never used them in my truck, but replaced them with the shoulder harnesses from the 62 (that also never get used, but whatever).
SOLD: 60/62 Mudflaps. Worn, but solid (surface rust only). $10.
FJ62 clock. $5, or make an offer. Clock in good shape, with pigtail, but unknown operation (came out of a junkyard). I intended to put this in my 60, but am too chicken
to cut up a perfectly good dash. Ahh well, I'll just have to suck it up and get the inclinometer.
FJ60 Dash switches: I have one rear washer switch (the others sold, including the pictured switch). As far as I know they all work. $1 each.
2F carb. Literally found this in the junkyard (someone had disassembled the engine). Always thought I'd use it as a core for a good rebuild, but headed SBC nowadays. The $24 I have in it will take it. It needs some TLC, but looks to be complete. The rust at the bottom is only surface rust (very minor).
D-pillar vents: I've got 3 for the US driver's side, 2 for the passenger side. I'll take $5 for a pair, $2.50 for the single. No cracks in any, and one of the pairs was painted in the past (look cleaner in the photo). Toes NFS.
I've got a bunch of other parts, but it just started raining here. I'll get photos and prices up here in a bit if I can. Ask if you don't see something; I don't mind digging around to see if I have one.
. Let me see what it is and if I have it, and I'll shoot something back--
