What would you all suggest for a Toyota engine to get 450-550hp without forced induction? Needs to be 6 cylinders and 4.5L or less and also have aftermarket parts fairly available (not a real oddball engine). Can run high compression and doesn't have to be real streetable since it's for offroad racing. Gots to be a Toyota
Thanks folks.
Nope;p not going to happen
The Class-7 Ranger guys are apparently getting around this hp (or more) with a 4.5L V6 Busch Ford engine. What's comparable with a Toyota engine?
Start with a 2JZ motor from a Supra. Super strong 6 cylinder under 4.5L.
Ryan
X2. Guy brings his over to his GF's house down the street from me and I guess his is pushing over 400 (with a turbo) and will be in the vicinity of 570hp after his next round of upgrades![]()
The 1FZ 4.5L has little to no aftermarket tuning support... with that said, you could build a heck of a nice engine with one.
The stroke is to long, it's made for torque and not a lot of horsepower.. the bottom end is to soft for making the high RPMs needed for making horsepower... it would be a lot cheaper and more simple to just go with a Oval or Bowtie... the Ovals weigh in about 110 pounds less than the SB Chevys..
Bummer, I was really hoping there would be something to compete with the Ford engine.
maybe you need something like ..
Not necessarily.
There are other yota engines than the ones that they put into trucks guys. What about a supra engine??
Does Toyota run *any* 6-cylinder engines in their racing cars or trucks? What are they using?
why NA when you can blo easily for cheap. But I wonder what a 4.5l 1fzfe could do with a better rods (available) and appropriate cam, a simple porting and 8000 rpms. already has the 7 bearing main.
mine is blown and runs great all day long![]()
I would look into the old Toyota PPI trucks from the 90's....
No 450hp 4.5L engine is cheap. Might as well take a 1FZ and do it up...
I'm guessing this for a Class 3 or 7100 car/truck. So, a turbo is out and so is the blower.
What did the V-6 Stewert's trophy trucks run before the Toy V8s were introduced in the mid to late 90's. That was a V6 with around 380hp????????? It's been a while.
I'll look when I get to the house tonight for the company's name and phone the worked with a lot to the toyota engines for desert folks.
-John
Thanks folks.
Yeah with forced indiction, you can run it till.............
http://www.youtube.com/watch?v=GzYl3cF-xMU
Umm...I need to go grab a tubesock nowthat supra has some work into it I think
Dood, that Supra on the road would worry birds the same as jets do. Ya know, suckin em down that sewer drain of a turbo intake.
brb tubesock time again
aw jeez I crack myself up,!!
also remember that all the toyota racing engines are inducted or turbo'ed or something, that kinda HP naturally is hard to make w/o the cubes.
If you are serious and acknowlage the rest I'd say 380-390 is possable
1: Resurch the 2jZ vvT-i head it will require a stand alone computer.
2: the lightest FORGED ALUMINUM con rods, all rods by different manufacturs are trade off's your not going for 1million miles so............
3: knife edge the crank, this removes weight and frees up higher RPM's
4: Aluminum pistons light weight better heat disapation
5: Port & Polish the head, max porting should have lower rpm's suffering though
6: biggest baddest valves avalible, air in air out, the better more efficient the more power genorated
7: dont know comp ratio but computer will have to be...er, massaged in order to read the signal and not trouble code it and not run (at all) correctly
8: use all the above data and get the correct cam's for it, over laping the valves WILL cause it to be Off-road ONLY
9: adjustable cam wheels will let you fine tune the cam's good idea.
10: about 100hrs on the dyno (seriously, I dont know how many hours)
11: I know I left some thing out damn ADD!!
The more you deviate from bore & sroke the more your buget will shrink I say leave it go with what you got (above) REbuildable and will FINISH the race
500!ahahahahahaha!!!!
