So I have 5 x 150 what? Is that mm thus it would be? Almost 6 inches for the circle?
5 1/2" from lug 1 to lug 3, but that is not the diameter of the circle?
"......5 bolt holes arranged around a circle which is 5.5" in diameter. This may also be commonly referred to as 5 on 5.5 bolt pattern."
Hers is my research
There are a few reason I could think off why they try the 5-150 bolt pattern:
-It would accomodate bigger CV joint
-Weight reduction although very minimal
-Ergonomic request from the assembly plant So I have 5 x 150 what? Is that mm thus it would be? Almost 6 inches for the circle?
What is more, the hub studs are 10mm and not 8mm, the splined length on the drive flange is longer and the front wheelbearings are bigger than the 80
Hers is my research
