4x4 Labs (1 Viewer)
davegonz
Keeping it Weird
Austin, TX
I might be ordering a 4x4 Labs rear bumper and wanted to know if anyone else was interested in grouping our shipping or maybe getting a group discount. Let me know. I might be ordering in the next week or so.
Luke is a one man show, so sometimes it takes him a while to get back to you with emails. He does answer his phone though.
I heard back from Luke this morning. Here are the prices and timeline.
Shipping is about $200
Right now we are backed up about 3 weeks. I get a $750 deposit to get into the queue.
the prices for everything are as follows. You can put parts and options together and add it up. If you have any other questions feel free to call or email.
thanks,
-luke@4x4labs
Basic bumper- kit $495 Welded and finished $895
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
Single swing out bumper- kit $895 Welded and finished $1375
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
1 large spindle assembly
1 swing arm assembly with 4 sleeves
Latch and latch plate
1 gas strut with ball stud
2 stoppers
Double swing out bumper- kit $995 Welded and finished $1495
1 main bumper shell
2 sides
2 side top tubes
2 d-ring points
towing crossmember
receiver
2 large spindle assemblies
2 swing arm assemblies with sleeves
2 gas struts with ball studs
3 stoppers
15. Accessories
Tire holder- kit $125 Welded and finished $225 Swing out clamp
bracket Main
upright
2 gussets
side clamps
top cap
3 hole tire holder
square tube receiver
3 wheel studs
3 lug nuts
Hardware
One, two or three gas can- kit $195 Welded and finished $395 Swing
out clamp
bracket Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
License plate bracket
Hi-lift bracket with standoff
Ladder #1 - kit $150 Welded and finished $350 Swing out clamp bracket
2 Base tubes
2 rungs
Ladder #2- kit $175 Welded and finished $375 The first rung on this
ladder
is sleeved just like the swing arms for a third accessory like gas
cans or a
cooler. It can be removed for regular access to the ladder.
Main hoop- long, you cut
1 round rung
1 square sleeved rung
Cooler basket- kit $225 Welded and finished $425 Swing out clamp bracket
Main upright
2 base gussets
2 tubing hoops your supplied dimensions
tube spreaders
bottom plates
2 basket gussets
ARB fridge basket- kit $225 Welded and finished $425 Swing out clamp
bracket
Main upright
2 base gussets
2 tubing hoops
tube spreaders
bottom plates
2 basket gussets
Bicycle rack, 2 bikes- kit $195 Welded and finished $295 Swing out clamp
2 base gussets
Rear tire plates
Rear tire plate crossmember
Rear tire hold down straps
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
16. Separate bumper parts
*Main Shell- Formed and plasma cut bumper shells for FJ80 and FJ60 $185
*Uncut formed main shells 72" wide- $125 *Formed laser cut side skid
plates-
$125 ea..
*HD Spindle assemblies- $95 ea.
*Swing out assemblies- HD spindle assembly, sleeved swing arm with gas
shock, ball studs and stops - $225 ea.
*Accessory bracket clamp- $25
*Towing receiver- $25
*D-ring tow points- $30 ea.
*Hi-lift bracket- $25
*License plate bracket- $10
*De-sta-co 4000 lb. Latch and latch plate- $95 *Gas struts 120 lb.
$25 ea.
*Ball studs $2.50
* 6" or 8" Gusset $9
*Accessory carrier retrofit sleeve/clamp kit- $29
I was planning on doing a DIY basic kit and the tire carrier kit. I already have 2 spindles from iron pig, I was hoping I could just use them to save some money.
Just called luke, and said we would save on shipping if we order together.
I could use a couple of D-ring points...
My budget says that I'm probably going to order the DIY kit. Did Luke say something about there being a 3 week wait for DIY kits, too?
Yes, I should be there tonight. I plan on getting a dual swing-arm DIY kit with the tire carrier kit and 3 jerry can basket kit.
Yes, I have a bumper on the 80 that was made by Iron Pig several years ago.
Remind me about the idea I have about carring jerry cans. I would like to see what you think about it.
On long trips, I have actually used the 3-can basket to carry a small Action Packer filled with stuff.
The only time I've had 3 jerry cans back there was on my New Mexico trip last year.
OK, looks like I have the cash for the DIY kit. Other than Guthrie, who else is ready to order?
When are you ordering?
Still trying to decide...would go with the DIY kit too.
Soon. You could just order the basic bumper and one swing-out. That will make it more affordable. I just have never seen how it's set up.
