Well my 3.0 died for the last time at gulches this weekend. So I'm going to do what I should done when returning from Iraq instead of patching up the 3.0. I have a 96 4.3L vortec that came out a friend's S10 (he swapped in a 5.3L) and a 97 Blazer that has a blown 4.3 but a newer 4L60E trany. I'll be keeping the Toyota dual t-cases with advance adapters t-case adapter and the same for engine mounts. The 4.3L that I have came with a set of JBA headers but I'm not sure if they'll work in the 4Runner, so more then likely I'll have to get a set of custom headers or use the stock GM manifolds. As for wiring, that one is still in the air because there are so many ways to go. I've seen a few shops online that will make custom plug in play harnesses but they are pricey. So there's about 75% of the plan.
Here's where I'm at with this swap. I pulled the Toyota's 3.0, trany, and t-cases today. I'll be cleaning up the 4Runner's engine bay this weekend by removing all unneeded wiring and whatever else I willnot need. I will also be pulling the 4L60E from the Blazer this weekend. It's at my wife's brother's house in Andrews along with the good 4.3L. I'm going to bring both of them back so I can go through 4.3L and I have to drop the 4L60E off at a trany shop to have the output shaft changed.
Does anyone have a cherry picker(engine hoist) that I can use for a week or two?
The 4Runner is also 2nd on my list of things to get done. I also have to fix my wife's 03 VW Jetta TDI that has a blown head. I have that engine pulled apart and waiting for the head to come back from getting repaired.
