- Location
- United States
This is a 1990 4bt 4 cyl cummins turbo diesel with low miles around 80k out of a freto lay truck . Runs awesome these motors are un stopable. It is mated to a gm th400 transmission in good working order it has a np205 transfer case with the 32 spline output shaft the strongest t case there is. The transfer case adapter is a custom adapter made from adam woodley at wideopendesign. It is made to clock the t case flat for ground clerance almost 15 degrees. I also have a brand new 4 core double pass aluminum radiator with 2 12 inch spal fans with shroud and a brand new intercooler. This is the perfect setup for alot of applications very hard to find it took 2 years to get it all together and now that i got what i wanted unfortenatly i have to get rid of it. i was putting it in my 1 ton full width toyota i have spent thousands on . Again this is a rare find i have all genuine cummins gaskets for the whole engine with the original cummins paint 2 cans. this is the real deal no bull so if you want it email me and we can talk. only if you are serious and know what this is. I am askin 2500 for all . call 720 435 2202 i am in longmont co 80501
