I have a 1992 4BD2T that I’ve just finished building a remote oil filter setup for that is similar to the one Doug720 designed. I need help with banjo bolts that attach the steel oil feed line to top of oil filter housing, injection pump, and pump gear cover. Two bolts have large holes and one has smaller holes. I know one of the ones with big holes goes in top of filter housing however I’m not sure if the one with smaller holes goes in the injection pump housing to help maintain oil pressure out to the end of the line (pump gear cover). I can also see where the injection pump would need more oil so maybe it needs to be feed by the bolt with larger holes. Any advice would be appreciated as I don't want to cause pump or gear problems down the road.
Thanks,
Don Ferguson
Thanks,
Don Ferguson
