4.75" Backspacing?
Yokosuka
I know the factory BS on factory wheels is around 5.75 to 6", but is anybody running 4.75"?
That or doesn't anybody have an idea bout how they will look with about a 1-2" Lift.
Thanks in advnace.
Maybe I misunderstand your question, but isn't that reduction in backspacing the same as using the slee/spidertrax adapters? Lots of pictures/threads of that here.
I will be running 18x9 Methods with +24 offset which is equivalent to 6" of backspacing. I am also running 1.25" Slee Wheel Spacers which should bring my effective backspacing to 4.75". The tires (275/70/18) Duratracs will look fine from my preliminary measurements.
For your purpose 4.75" of BS will work just fine. You could even go a bit more aggressive if you wanted.
the slee spacers push your wheel 31.75mm (approx 32mm) away from the truck.. your method wheel is +24 ET or offset. the combination of your choice wheel will push you across the 0 offset and give you ultimately a (negative) -8 offset. Thats aggressive but i dont think 8mm is going to ruin your day. Ive seen 0 offset work fine .. cant wait to see what you come out with.
I love Method wheels. They are gonna look rad. Worst case scenario - you ditch the spacers or do some trimming and banging.
Post pics when it all happens
GL
Thanks for the feedback guys. And yes, JC, that is exactly what I'm thinking, I know guys use spacers on the Rockwarrior wheels, but didn't know how common it was to use spacers with factory wheels. I really just wanted to check myself.
And its funny you guys mention methods, the whole purpose of this thread was because i found some method double standards with KM2s local for sale cheap.
I think double standards will look good. I went with NVs
