3FE Piston Rings Needed
Hello Everyone,
The short bus is disassembled and spread all over my garage. I'm about to start putting the motor back together but Toyota does not have piston rings for my 91 FJ80. I'm looking for a set of standard size rings. I would like to use Toyota rings but since I can't get those what is the best after market option?
BTW Rod bearings and main bearings are also not available from Toyota.
Thanks for the help,
Brad
Not sure if the FJ80 is the same as my 89 FJ62. I had a lifter noise and just be sure I replaced my rod bearings. I remember on the bottom of the block there is a letter that told you which bearing you needed for each. Everyone of my rod bearings were in the almost no wear when measured. I kept them in the OEM boxes with each cylinder number marked on the box. Sure hope I haven't thrown them out.
Curious how this size by letter will effect finding aftermarket. I have a 92 3FE I was planning on going to thru.:hmm:
