I am in the process of replacing all my fuel lines on my 1990 BJ73 with a 3Bii. The one from the Injectors returning to the IP was cracked (and there was another that was replaced by a PO with radiator hose line). I cannot find a part number for that hose. Looks to be a 5.5mm hose, but has English writing on it, unlike all my other hoses so I am not sure its stuck. I have some 6.3mm hose I can use and seems to seal, but I wanted to check here if someone knew the correct size.
Now for bleeding the 3Bii, there is no visible hand primer on the IP like the 3b. I can snap some photos in the morning when its light, but I cannot figure out where it is. There is a primer on the fuel filter housing (see photo). Do I just use that?
IP for the 3bii:
Fuel line:
IP for the 3bii:
Fuel line:
