I've had a few people ask about my Blow off valve setup , so here's a quick rundown of the setup. Pretty straightforward stuff. Hardest thing was deciding where to put it.
#1. in the pic is the BOV mounting flange/adapter. This is the most common flange/adapter. It uses two bolts to secure the bov to the intake pipe.
#2 is the BOV itself and there is a adjusting screw at this end to adjust the blow off pressure. you can take the cap off and youll find 2 springs inside the top cap. I had to take one out to get the release pressure down to 3-5 psi, but it all depends on the brand you get. turning the screw out gives less preload on the spring that holds it shut->higher release pressure and vise versa.
#3 is the reference line to the intake manifold AFTER the butterfly. Your reference must be after the butterfly valve/throttle plate to work. This is what holds the BOV closed under boost. Same pressure to both sides of the system. I mounted a Tee in the glow plug resistor hole(#4). I have manual plug system on mine so i dont need this resistor. Cant remember the hole size but its a weird thread. I think i used 3/8" or 1/2" NPT fitting with teflon wrapped around it thick to get a good seal. hasnt popped yet....
The copper line is my boost guage reference. If you want you can drill and tap the manifold anywhere with a 1/8" npt tap and those fittings are easy to find anywhere.
Results are reduced boost lag between shift(turbo isnt stalling from back pressure from the throttle plate.)
Sounds cool.
cheers!
Sounds cool.
cheers!
