33x12.5 rub where?
South Africa
Guys with 33x12.5 tires on 10x15 wheels and a 2.5 OME. Does the front tire rub on the front or rear of the fender under compression?
I have 33 x 12.5s with no rubbing. The suspension is a standard OME medium kit. The tires do rub on the side of the tail pipe, but not on the body of the truck. Factory bump stops are in place.
I have my 33x12.5 on the stock rims and they rub in the rear wheel wells and on the front springs. It looks like I need some wider rims for these tires.
three years with OME and 33x12.5 on 15x10 rims and they do not rub.
Strangely, mine rub pretty bad in the front, I have OME medium with some extended shackles and the front tires rub up on the side of the fender, its strange to explain, but in some situations of turning on an incline the body will roll over just enough for the fender to catch the lugs of my tire right on the top, its also only on the left side.
