Anyone know the bearing sizes for the 2UZ-FE alternator? I want to add some to my spares kit in case they fail on a long trip.
Been researching parts to rebuild my alternator (I have an 2005) and stumbled across your post. I couldn't find this info anywhere, but this is what I uncovered so far, but cross referencing different service manuals, toyota part listings, and replacement part sites. I am doing the same for the starter. Please comment if there is an error!
I believe the recommended bearing should be dual side shielded (-suffix code should be like: VV or 2RS or DDU). Koyo, NSK, Nachi? I believe most of the OEM bearings were Koyo.
1998-2000
80 Amp Alternator Uses:
a) Front Bearing: 2021 (6202 wide): 15mm ID x 35mm OD x 13mm W ?
(6202 normally is dimensioned: 15 x 35 x 11)
b) Rear Bearing: 3042: 17mm ID x 52mm OD x 16mm W ?
1999-2003
100 Amp Alternator Uses:
a) Front Bearing: 2021 (6202 wide): 15mm ID x 35mm OD x 13mm W (Toyota 90099-10194)
b) Rear Bearing: 3042: 17mm ID x 52mm OD x 16mm W (Toyota 90099-10192)
2004-2008
130 Amp Alternator Uses:
a) Front Bearing: 2021 (6202 wide):15mm ID x 35mm OD x 13mm W (Toyota
90099-10140)
b) Rear Bearing: 303 (6303): 17mm ID x 47mm OD x 14mm W (Toyota
90068-10142)
