Welcome to MUD!!
First off, it
appears, from your pictures that you tank is welded to the frame - if so, that's gonna make it harder to drop your tank.
Regarding your sender question - if there's a sender, it would most likely be mounted on top the tank - you would need to be able to access the top of the tank to check it - he easiest way to determine whether you have a sender is to look for wires coming from the top of the tank - there would be a wire running from the sender to the gauge and a second wire to ground the sender - probably to a bolt near the tank. Ther
could be a third wire... if there are no wires, there is no working sender.
My
guess is that you have an oem main tank, running to the oem fuel gauge and an auxiliary tank that does not run to the oem fuel gauge...
The valve on the floor would allow you to run the aux tank dry and then switch to the main tank, with a working gauge.
But, this is all a guess...
For the switching valve...
- I would get a few buckets ready and disconnect the hose coming from the aux tank to the valve and drain the tank into the buckets (unless you are sure the aux tank and gas are clean). You can crimp the fuel line to change buckets.
- I would do the same for the main tank (again, unless you are sure the main tank and gas are clean)
- Swap in a new valve - or, if you want to share the oem fuel gauge, between tanks, install an electronic switching valve (like Pollak or others). is would require the aux tank have an oem sending unit or another sender that works at 120ohms empty and 17ohms full. I ran into issues trying to use a Centroid sender because they have changed to digital senders that no longer work with the self-regulated oem fuel gauge. Its just easier to make an oem sender work - you may have to lengthen the sender's float-shaft.
- Replace all your soft lines and blow out your hard lines - or, replace them if they are not good lines.
It would be much easier, at this point, for you to just swap in a new valve and run your non-gauged-aux-tank dry, then run your gauged-man-tank. That way you don't need to know how much gas is in your aux tank - just switch wen it's going dry - or, switch when you have reached some 'estimated mileage' threshold.
But,
I would want to know both tanks are clean - it
looks like it's been on there a while and it could be full of crap... dropping the aux tank may take grinding off the welds (if that's how it's mounted) or a cutting torch and
you will want to be very careful using heat around a gas tank - even an empty one - I would take to to a professional to have this done and find a better way to remount it.
I would also, pull the main tank and clean it and check under it for pin holes and rust - you really want it to be clean as well.
You
may want to consider re-mounting the aux tank with a skid plate and hanger system - Jim (
@Downey on MUD ) may be able to provide a solution for this. He may respond here or you can start a conversation with him here, on MUD.
hth
