- Location
- United States
Parting out my old 2LTE short block. The block is in need of re-bore, so is not really worth anything. However, the crankshaft and rods are in perfect shape. Pistons are in good shape (would need new rings obviously). Oil pump, oil sender, crank position sensor, rear main seal retainer, oil pick-up, oil cooler, piston oil squirters, are all in good shape. Oil pan is in good shape too, but I may keep that as a spare.
Open to reasonable offers and will ship anywhere at buyer expense. I'll take pictures if there is any interest in the parts.
The reason I removed it from the truck is the original owners in Japan let water sit in the cylinder bores when the head cracked eons ago. This made for above average blow by as the bores were a bit damaged from rust. So I replaced it with another short block.
