Jonathan_Ferguson
★ is in the wrong locale
- Joined
- Jul 2, 2003
- Threads
- 132
- Messages
- 950
- Location
- Glen Waverley, Victoria, Australia
- Website
- jonathan-ferguson.au
How many Nuts and Bolts hold it on?
Jonathan_Ferguson said:I removed the four Bolts on the right side, and the Bracket.![]()
I've also removed two Nuts from behind the Timing Cover. Am I right to hit it with a soft Hammer?
To get the Engine out, all I have to do is get the Injector Pump off, remove the pivot Nut and Bolt from the Alternator, and remove the Bonnet.roscoFJ73 said:Are you sure it doesnt need a puller like the 6 cyl pump?
I had to use a puller,a hammer and a lot of swearing to get the 1HZ pump off
Whats the latest on your engine?
Jonathan_Ferguson said:To get the Engine out, all I have to do is get the Injector Pump off, remove the pivot Nut and Bolt from the Alternator, and remove the Bonnet.![]()
Currently, it looks like the left side of the Injector Pump sits on two Studs comming from the back of the Timing Cover. - I can't see how a Puller could be attached to it.roscoFJ73 said:So are you using a puller to get the inj pump off? I dont think there is any other way.
I was told to tap it with a soft hammer when the puller was as tight as could be.
Jonathan_Ferguson said:Currently, it looks like the left side of the Injector Pump sits on two Studs comming from the back of the Timing Cover. - I can't see how a Puller could be attached to it.
