4Ruster
2LT Sufferer
I am just finishing my 2L swap in my 1986 4runner. It was originally a 22re engine, I dropped in a 1984 2L diesel. I had to wire the alternator up myself due to it being on the other side of the engine so the old wiring harness wouldn't reach.
BATTERY TERMINAL: I have dual batteries installed, I just ran a 4 gauge wire from the alternator straight to the positive terminal of the battery connected to the fuse box, it is connected to both battery positives.
LAMP: This I just connected to the existing connector on the original wiring harness, just ran the wire across the rad support.
SENSE: This is hooked up to the thick white wire that originally was the battery wire on the original harness, it connects to the fuse box after the big 80 amp fuse.
IGNITION: I was getting cold and just hooked this up to a random connector that received power with the key, I think it was the connector that supplied power to the injector box from before the swap.
When the ignition is on, I am getting now battery warning light, and when the engine is running it does not charge.
