Wanted 2H voltage regulator wanted
Boston, MA
Any ideas on an external voltage regulator for an 87 12V 2H? Thanks!
3 possibilities:
1) look at the australian ebay shops, by typing 2H toyota into ebay. Neil at Roodogs spareparts will be able to find one for you.
2) if you have the part number (should be on the old regulator), give Marv Specter a call. they have a lot more diesel relays and regulators in stock than on their website.
3) buy an external regulator for a 2F engine-you can get them at CCOT, or SOR. open it up in parallel with your old one. then you can take your old connector, and swap it, routing the wires how they should be (which you can see on your old one). works perfectly.
cheers,
Jan
He was sent a new alternator that needs a external reg. His old alternator had it inside.
Do you still have the old alternator? If so, maybe you can merge one together.
4wheelauto sells new internal regulators for alternators.
Ah, I see. so ist the plug still on the harness? the SOR people might be able to match that up.
j
I have one I can send you. It came from a '84 Aussie 2H.
No charge. PM a shipping address.
:cheers:
