torfab
Supporting Vendor
This car is new to me, and I'm hoping to get the engine worked out to use it in a project. I may end up rebuilding it, but it runs great when warm so I'm staying optimistic.
The glow plugs have an oily coat when removed. I ran a compression test, and the tester gets oil on the tip after removed as well. I got a 300-400 psi compression in cylinder 1, but the gauge must have oil in it from testing because now it won't give me a reading anymore, not even in cylinder 1 again.
The engine smokes when fired up, and is hard to start due to several glow plugs not working. When it gets hot, it runs really nice and doesn't smoke (unless I'm accelerating). It starts up in 2 seconds after it's already hot, and doesn't smoke.
Since the combustion happens from the precups, and any oil in there should burn away, then I'm curious why it's still on the glow plugs when removed.
I'm not opposed for a complete rebuild, but hopefully someone here has a theory or two for me to ponder?
