I'll take the valve cover for $75. Does it include the oil filler cap and head bolts on top? Inform me of where to send PayPal and shipping $. Thanks, Major-Don
Are you still interested in the rocker arm assembly? I would do $65 plus shipping. Thanks Dan
Sold that part....sorry
looking for the bracket below the alternator, green circled. And the tube coming out of the bottom of the thermostat housing
Do you have the camshaft oiler plate that's behind the timing gears ?
Attached pic for reference
Anything left on this? I need the short block.
I have an 82 2F out an FJ60. Everything is up for grabs. I also have a 4 speed behind it. I am keeping the Split case. Prices for a few of the bigger items see below. Also more pictures below.
-Oil Pan $75.
-Distributor and Side Cover Sold
-Intake $50
-Carb- SOLD
-Alternator sold
-Starter $75
-Power Steering pump SOLD
-Thermostat housing Sold
-Fan and Clutch $50
-4 Speed $150
-Harmonic Balancer sold
-Coil and Igniter Sold
-air filter housing sold
-Hard coolant lines sold
-Bell housing and flywheel sold
-oil cooler setup sold
-Other bits and Pieces please ask!!!!!
I have a good down pipe also. I have a low mileage manifold off my Dads FJ60 when he switched to Headers (ONLY 87,000miles) sold The manifold off this motor one of the mounting studs for the down pipe flange broke off so it had been drilled and tapped out to accept a bolt. If you have an interest shoot me an offer.
-I don't have much for smog stuff (Other then Pump) or any AC stuff (I have the mount bracket for the pump). High mileage motor but everything was functional.
I can get better pictures later this evening. Shipping is not included in the prices. I will try to fit small stuff in flat rate boxes. PM me with requests. Thanks
I need an oil pan. They're the same for a 2F '78 right? Any chance you could email my yahoo? gregoryfj40@yahoo.com or even call 2039135924 even better!I have an 82 2F out an FJ60. Everything is up for grabs. I also have a 4 speed behind it. I am keeping the Split case. Prices for a few of the bigger items see below. Also more pictures below.
-Oil Pan $75.
-Intake $50
-Carb- SOLD
-Alternator sold
-Starter $75
-Fan and Clutch $50
-4 Speed $150
Thorsic...if he doesn't have one pm me. Don't know if I'll be using mine or not...Carb cooling fan?
yes, an 85, its really clean but someone started on a v8 swap then quit. I'm resurrecting it with a 78 2F. This is the 2nd one I've had but still don't know what I don't know...Great thanks. I will see what his response is. Is yours also out of an FJ60?
