djawahir
- Location
- United States
These are parts from my FJ60.....
Here's the list of things I've got for sale:
H42: $200 (208k on the tranny)
Thermo-sensor: $80 (comes with the connector and wiring)
catalytic converter: $20 (original cat. passed smog with it. still usable.)
Flywheel, clutch cover, clutch plate: $100 (5000 miles on this clutch setup. Still many miles left on it...)
2F motor mounts: $20 (rubber is still good on these.)
Body mounts and hardware: $20 (rubber is still good on all of these. Front two are worn a bit, but the rest are fine.)
Exhaust downtube: $40 (This is the tube between the Exhaust manifold and the cat. Comes with check valve.)
New exhaust check valve: $20
Evap Canister: $40
Evap Canister purge valve: $10
Rear Main Seal: $5 (new and still in package)
K&N Air Filter: $20
Air Cleaner Assembly: $40
Fan with almost new fan clutch: $100 (2000 miles on the fan clutch. Bought it brand new and it's still practically brand new.)
2F radiator: $20 (tiny crack on top of radiator. Worked well when pulled, but it probably could use a re-core.)
Emission control computer: $30 (Still works. Original one! Comes with plastic cover)
Emissions parts: VARIES Let me know what you need!
Choke cable: $20 (comes with pull-switch and entire assembly)
Front axle spring seat: $40 (This is the heavy plate that goes under your axle and spring pack and has that tab that the bottom part of the shock attaches to. You get both of them.)
Power Steering Box Gasket Set: $80 (Bought from SOR and I never used it. Still brand new in the package.)
Power steering cooler pipe: $30 (in good condition.)
OEM Bottle Jack with bracket: $50 (Stock FJ60 bottle jack setup that fits in DS rear panel. Still works and looks good!)
Carburetor cooling fan: $20
Fuel tank feed/return pipe module: $10 (This is the part that bolts to the fuel tank and has the fuel feed and fuel return pipe on it.)
Fuel cooler pipe: $20
Vapor separator: $30
Engine: SOLD
Spare Carburetor: SOLD
Distributor: SOLD
Rear Heater: SOLD
Rear Heater hard lines: SOLD
2.5" stainless exhaust with flowmaster 50 series muffler: SOLD
Front brake rotors: SOLD
Side view mirrors: SOLD
Note: This truck has only been driven off road a handful of times and since it's a CA truck, there's very little rust...very little.
Thanks for looking!
Dylan
Evap Canister: $40
K&N Air Filter: $20
Engine: SOLD
Distributor: SOLD
Rear Heater: SOLD
Thanks for looking!
Dylan
