I've said this before in other threads, but I think it's important to keep mentioning. Suspension tuning is driven by a confluence of many different factors.
What seems a bit backwards to me is that we are talking about spring rates in order to maintain static ride height against weight.
Generally, proper springs rates are driven by dynamic performance needs. Yes, weight is a consideration, but choosing the proper rate is more about the ability to adsorb bumps without transferring that energy into the chassis, while keeping the chassis (weight) controlled. For serious off-road, softer is an advantage. Just like we say more sidewall is an advantage. Seems really odd to me that we are chasing such high spring rates to make things "better". Back to the confluence of things, yes, higher spring rates may sag less with weight. But does that really make off-road performance better? And what is off-roading to you? To have the highest ground clearance for obstacles when rock crawling where maintaining all the clearance you can with the stiffest suspension possible is better performance? Or bombing down that irregular washboard road where compliance is the utmost of importance to performance?
As mentioned, stock spring rate is 170 as a baseline. We're talking about upping that rate double to triple? For a 500-1000lbs more? When a doubling could handle double the curb weight at stock compliance (6000 -> 12000lbs). Doesn't that seems odd when looked at that way?
Too stiff of suspension, while feeling great to immediate turn in, actually reduces traction. On-road, but especially off-road. That's because the suspension no longer absorbs the hit, and transfers the energy into the chassis, upsetting balance. And not allowing the tire to maintain its contact patch on the road. There's lots of technical articles to this, a quick search shows this one -
Why Stiff Suspensions Have Less Grip
So back to my point. Choose spring rate first for the best balance of ride/traction/stability. It's too bad that I don't see adjustable perches on the BP51s (or is there?) to adjust ride height. Beyond that, one should use spacers or trim packers to tailor desired height for obstacle clearing. Not the other way around. Otherwise it'll be like a Ford F350 that's built for load bearing without a chance in heck to flex for off-road.
