For Sale 24V OEM Starter almost new
norcal
This came off a Toyota test engine that was only started a handful of times. Virtually new. Not reman. Not aftermarket. Virtually no wear on the gear.
Has the 2L nose come but will work with just about any Toyota Diesel engine if you install your existing nose cone. They takes ten minutes and you'll end up with a new OEM starter.
$100 plus shipping.
I have a handful of used 24V starters also for $40 us shipping.
Georg @ Valley Hybrids
The "nose cone" is the potion of the starter that bolts to the bell housing. It's attached to the main starter body with three Phillips head screws ( use an impact driver to loosen them; they're in there very tight so make sure you don't strip them out ). There are also two 10mm hex bolts on the back of the starter motor that go all the way thru into the nose cone. I can email you pics.
