24F AGM Battery for $146
Show Low AZ
Advance autoparts has 30% off on there products right now. Just put in the code HX4LBX
This means thier $196 24F AGM Battery, after your get your $22 back from the core charge, is only $146.
Seems like a good deal
AutoCraft Platinum AGM Battery, Group Size 24F, 710 CCA 24F-AGM: Advance Auto Parts
Also, I guess Advance Auto Parts is also know as Car Quest, so if you need to you can return your core to them or if you have a AAP close by.
I had a crappy WalMart NeverStart that I had to replace 3 times in 4 years, lately its issue was not starting when the temp goes below 32f. I put in the APP AGM battery and so far so good.
I had a look but can’t find the reserve capacity. Particularly interested in the 20hr rate. Anyone have the full specs?
This isn't a PIC of the battery in my TLC but I'm pretty sure its the same battery make/model.
It states 70 Amp hour and reserve capacity of 120. Pretty sure that is 120 Mins...
One last tip with APP, if you buy a qualifying product from them they'll send you a $20 off coupon. Since my Honda Ridgeline has the same battery (24F) I bought one for it too, only I got a total of $70 off (30% or max of $50 + $20) bringing this down to $128! That is a steal for a AGM Battery....
More $$ off... if you want you could refer a friend to get an other $30 off.
Advance Auto Parts - Down for Maintenance
Looks like there are a lot of options here to get $$ off right now at APP.
And no I don't have stock in them... yet...
