For Sale 24 v PUMA Air Compressor
Kelowna, BC
The 12 vdc PUMA is a ruggedly built air compressor and easy to get off Ebay , but the 24 vdc PUMA is not commonly available.
I have several PUMA PD-1006 compressors with a ¾ hp 24 vdc motor for sale. The 24 vdc PUMA comes with a screw on air cleaner, a 6 litre (1.5 US gallon) pressure tank, pressure gauge, pressure regulator with its own gauge, pressure relief safety valve, tank drain, a Quick Connect and 10 gauge electrical cable and battery clips. Most people bolt the PUMA in their truck and wire it to the battery and use a 25’ flexible hose from the supplied Quick Connect.
Air up times are as follow:
  • 35 x12.5 R15 MTR = from 16 to 42 psi in 2.5 minutes
  • 315/70 R16 MTR = from 18 to 44 psi in 3.0 minutes
The PUMA 12 vdc has excellent reviews on the Mud board. The PUMA 24 vdc has a little bigger cylinder head than the 12 volt model.
If you have 24 volt electrical system and want to move up the 24 vdc PUMA please send me a PM. They are $350.00, including shipping. Please send me a PM if you are interested.
