- Location
- United States
Two used 24v-12v converters for sale. See specs below.
Came in running vehicle and were working. Both come with instruction manual.
$50 each. Located 1Hr east of Vancouver. Can ship.
SDC-23 24VDC-12VDC Converter, 20 Amp
This high efficiency switch-mode step-down DC-DC converter converts an input voltage of 24 VDC nominal (range 20 VDC to 35 VDC) to a highly regulated output voltage of 12 VDC nominal (13.8 VDC) at 20 Amps. The SDC-23 DC-DC converter is non-isolated (no galvanic isolation between input and output) and meant for use in negative ground systems. Features include overvoltage/short-circuit protection, temperature compensated current limit, output-side overvoltage protection, input-side overvoltage/ transient protection and input-side reverse polarity protection. The SDC-23 DC-DC converter is designed for heavy duty applications. 88% efficiency at max output.
The ICT2412-10A converter will provide continuous trouble-free power. It is designed for high efficiency and long service life. The rugged case and modular design have proven durable in harsh environments. Extra silicone is used for vibration and moisture resistance. Standard features include: easy access mounting holes, a terminal block connector, current limiting, overvoltage protection, fuse protection, and a high surge capacity. 86% min Efficiency.
