- Joined
- May 18, 2015
- Threads
- 2
- Messages
- 7
- Location
- Golden, Colorado
- Website
- www.douglasvanbossuyt.com
Short version: Long story short, I drove from Colorado to California on Sunday only stopping for gas in my 1988 4runner DLX (22re, 156k miles). The starter became progressively more sluggish until on my last two fuel stops, I had to push-start the truck. The next morning after the truck cooled down, it fired right up multiple times and had no problems. Even while the starter was barely turning the engine over, the truck drove fine. Should I be replacing the starter (replaced with a remanufactured unit a month ago and no problems until now) or is something else possible?
I originally posted over on my awesome local Toyota 4x4 forum and it was suggested I replace my starter with a genuine from the Toyota dealer remanufactured unit as insurance against further problems. I'm posting here to see if you all have any other ideas that I should try before or at the same time as I replace the starter. Original post here: http://www.risingsun4x4club.org/forum2/showpost.php?p=269438&postcount=134
Longer version: I started from Denver at about 4:30am. The truck started up fine. I stopped near Vail to use a toilet (okay, I lied before. I stopped once for non-gas reasons). The truck started up fine. I stopped in Thompson, UT for gas. The outside temp was probably about 80F at this point. The starter was slugish but the truck started up and ran fine. Next stop was St. George, UT. I pulled into an AutoZone to get my battery tested (thinking maybe it's not holding a charge). The battery was fine. The truck wouldn't turn over but was barely trying with my foot pushing in the clutch. I was able to get it to barely to turn over and run by using the clutch cancel start switch (lower left below the steering wheel on the dash). I pulled across the street, got gas, and was able to use that clutch cancel switch to get it started again. Outside temp was 112F. Still not using AC at this point because I was trying to conserve fuel and also all of the hills needed the full power of my 22re.
Across Arizona and Nevada, I saw outside temps up to 117-120F in a few places. It was damn hot. I broke down and used the AC sparingly when the steering wheel became too hot to touch.
In Barstow, CA I stopped for fuel again. Outside temp was around 105-110F. Found a gas station with a bit of a hill on one side. Got gas. Went to start up but it didn't want to turn over. I roll-started and it fired right up and away I went.
In Fresno, CA I stopped for fuel yet again. Now the outside temp was around 85-90F. Again it would barely try to turn over. Luckily there was yet another hill. One roll start later and away I went.
The next morning after sitting in the cool air for nine hours (60F outside) the starter cranked strong and fast, the truck started up, and away I went no problem. I stopped and started several times and the starter functioned as it should.
I haven't driven the truck in such hot weather or for such a long distance before (just got it a month and a half ago). The starter was replaced about a month ago with a remanufactured unit from O'Reilly. At the time I didn't know that I could get parts to rebuild my own. Everything else with the truck is working well (good compression in all four cylinders, all fluids except for power steering an coolant have been changed in the last month, good voltage according to my voltmeter I put in the dash, etc...)
I was looking through Roger Brown's guide to starter troubles ( http://www.4crawler.com/4x4/CheapTricks/Starter.shtml ) and thought maybe I could be having troubles with a flaky ground or something else along those lines. While I was driving across the desert, I didn't feel like trying to get to the starter in the engine bay to try and jumper between the solenoid and a positive voltage source.
Any thoughts on what I should be trying to chase down aside from replacing the starter again? I'm okay with push starting the truck but I figure it would be nice for the drive back to have it start normally.
