22RE help
Swanzey NH
I'm replacing a leaking seal, crank pulley.
The bolt that holds it on is normal threads right?
Not reversed or anything.
Thanks
Lane
I got it!
19mm socket, 3/4 drive breaker bar resting on the drivers side
frame rail.
Pull coil wire, bump starter, Free at last!
good thinking that bolt can be a real pain, i just put a chain wrench to the frame and get on the nut with a breaker bar thats being helped but a 2 foot jack handle:D
I have everything apart right now, the pulley has a bunch of grooves in it, probably causing the leak. Picked up a speedy sleave today and just put it on.
If I didn't have Boy Scouts tonight I could have it back together.
Thursday evening I have a meeting with Scott H. and the local trail club, so it looks like Friday. I may put that Tube bumper on if I can figure out an easy way to mount the turn signals.
