First off, thanks to the guys that replied to my other thread.
I need to hear pro's and con's on the following options I'm struggling with.
This engine is for an '85 4x4 with a 22r:
Get original block bored and buy new piston heads and rings and new head. The head from this engine had two small cracks that couldn't be ground out due to how close the would be to getting into the valve seats.
or
Try to fix the engine that is in the '83 (22r also). It has low compression in the 4th cylinder (headgasket, I hope?). Take the hopefully fixed engine from the '83 and put it into the '85.
I'm not in a bind to get this done so I can't decide if I want to save up more money to get a new head (most likely from Engnbldr) or wait it out to see if I can find a good head from someone that may have done a non-Toyota engine swap.
What are the chances of even getting a used head that is going to not be trashed also?
I'm not going to use this truck for hardcore off road work but I do want it to be put back together so it is reliable and not going to have fits with it forever. I don't want to have it shoot craps on me for a rookie mistake that I might make now.
Thanks again for any experience based advice you guys can give me,
Hoss
or
Hoss
