2019 LC200 A/C turns off on engine restart and recycled air still smells of the outdoors.
Houston, Texas
Hey guys, basically title. I saw a few older threads but couldn’t really find a direct answer. Would appreciate any help.
It's super likely the retractable door that changes the HVAC airflow from outside to inside has been damaged by someone who didn't know the system must be in RECIRC to access the cabin filter compartment when the filter is changed. You can check this by putting the HVAC in RECIRC and then looking at the retractable door operation when you change from RECIRC to FRESh. Access the filter area by removing the small panel at the back of the glove box. My bet is the door won't move properly. Don't force the retractable door to move. That's what breaks the mechanism. There is a fix from a Mud member. I'll dig up the link.
Legend, thank you.
Just wanted to follow up. Thanks again for your initial response. I checked, you are right, the door doesn’t move when going from recirc to fresh. Above you mentioned to not move the door, being that is is inoperable already, is there any danger in moving it to recirc manually, or should I just stick it out on fresh until the part comes in and I do the replacement?
I would leave it alone. The fix is fairly easy. It might be possible to make things worse by moving the door manually. Just enjoy the fresh air for a few days. :cool:
