After replacing rear axle bearings and backing plates it is time to tackle shocks replacement - 2010 LX with 135k miles and some HD towing. I have few questions to been there and done that. I would also be replacing all 4 AHC globes to make it into one AHC fluid swap. New AHC pump was installed last December but I bled the main accumulator only so still plenty of old fluid in the system.
1. Is 3.5 Toyota 2.5 l cans of AHC fluid enough for the job?
2. Should the replacement shocks be prefilled prior to install or mounted dry and I should let the AHC ECU and pump handle the fill?
3 What other suspension components should be done or looked at at the same time? Control arms? Bushings? SwayB? Ball Joints? Springs? Cones? Rubber bump stops or pillows?
4- Rears are PITA with no access and are known to put up a fight - is sawzall the solution or as someone floated idea of cutting access hole from the interior of the car?
5. Can hardware like nuts and bolts be reused or should I consider new hardware considering I’m in the rust belt, keep it under control but war on rust is like war on drugs - type of war you fight but never win?
6 Can I restore proper wheel alignment with markings or new alignment would be necessary?
7. Can I do it all on the lift or some parts like AHC bleeding be done better with wheels on the ground?
Any other tips or tricks I should know about?
