- Location
- United States
For sale in Connecticut, a 2010 Harley Davidson Dyna Fat Bob. I bought this bike on the 27th of March, 2010, at Bridgeport Harley for $17,264 out the door (after taxes, fees, etc). The bike is completely stock, with the following exceptions:
1. One-Piece Detachable Tall Passenger Sissy Bar Upright - Gloss Black
- This, with the detachable mounting hardware came to somewhere around $275 out the door, again at Bgpt Harley.
- This is the item: One-Piece Detachable Tall Passenger Sissy Bar Upright - Gloss Black | Genuine Motor Accessories | Harley-Davidson USA
- This is quick-detach, takes just seconds to remove / put on.
2. I bought a stock air cleaner cover online, prepped and painted it "rubber spec black". Here are some photos:
- Original Chrome Air Cleaner Cover: http://img375.imageshack.us/img375/6287/35099144.jpg
- Painted Air Cleaner Cover: http://img718.imageshack.us/img718/5104/87513840.jpg
- ***Note: Both covers will come with the bike, unless you dont want one. Just let me know which one you want on (its a 30 second install; one screw)
3. I put a small bag above the lights. I use it to carry the registration / insurance, as well as my phone/wallet
when need it. It's not name brand, but it's stout. You can see it in the photos below.
4. I put on Rush 2.0 Baloneycut SlipOns. Sounds awesome.
5. A softpack that attaches to the sissybar, used for trips. It has one broken clip but I've used safetypins instead, works great.
6. I've put extenders on the passenger pegs. This way, a tall wife can ride on the back. Even better, the rider can use this as another foot position.
7. I've put on a Harley brand engine guard, powdercoated black. Doubles nicely as another foot position.
As mentioned above, I bought this vehicle in March and drove it occasionally to work, and around. Mileage is appx 1400.
Cosmetically, it is 99.9%, as it has one bootheel scuff on the heatshield. This aren't tough to get out though. It runs great, rides great (6th gear is
great on the highway), sounds mean, and is just overall a great bike.
This would come with the following:
- Any paperwork I have associated to the bike, including the original sale reciept (which states Warranty: 2year Unlimited Miles by Harley Davidson Motor Company), original Odo Statement
- Owners Manual
- Technical Literature List
- Parts Manuals.
- 2010 Dyna Service Manual ($75 new)
- A set of dyna mid-peg takeoffs. I was intending on installing, for another foot spot.
- Any other bits and bobs I have sitting around that belong with the bike.
Overall, what you'll get here is a new-quality bike, at less than dealer price. As I am only selling because I hate to see it sit.
Clean title in hand. Ready to rock. Cash talks!
If any questions, please do not hesitate to ask.
Engine:
Engine Type V Twin
Cylinders 2
Engine Stroke 4-Stroke
Cooling Air
Valves 4
Valves Per Cylinder 2
Valve Configuration OHV - Pushrod
Compression Ratio 9.2:1
Starter Electric
Fuel Requirements Premium
Fuel Type Gas
Transmission:
Transmission Type Manual
Number Of Speeds 6
Primary Drive Belt
Wheels & Tires:
Front Tire (Full Spec) Dunlop® 130/90 R16 67H
Rear Tire (Full Spec) Dunlop® 180/70 R16 77H
Brakes:
Front Brake Type Dual Hydraulic Disc
Rear Brake Type Hydraulic Disc
Technical Specifications:
Wheelbase (in/mm) 63.7 / 1618
Fuel Capacity (gal/l) 5 / 18.9
FXDF Fat Bob®
DIMENSIONS
Length 91.7 in. / 2329.18 mm
Seat Height
Laden 2 26.1 in. / 662.94 mm
Unladen 2 27 in. / 685.8 mm
Ground Clearance 4.92 in. / 124.968 mm
Rake Steering Head 29 °
Trail 4.92 in. / 124.968 mm
Wheelbase 63.7 in. / 1617.98 mm
Fuel Capacity 5 gal. / 18.925 L
Oil Capacity 3 qt. / 2.838 L
Dry Weight 669.7 lbs. / 303.77592 kg
Running Order 703 lbs. / 318.8808 kg
Luggage Capacity
POWERTRAIN
Engine 3 Air-cooled, Twin Cam 96™
Displacement 96 cu. in. / 1584 cc
Bore x Stroke 3.75 in. / 4.38 95.25 mm / 111.252
Engine Torque J1349 J1349
Engine Torque 4 92 ft. lbs. @ 3000 rpm 124.7336 Nm @ 3000 rpm
Fuel System 5 Electronic Sequential Port Fuel Injection (ESPFI)
Primary Drive Chain, 34/46 ratio
Fuel Economy
Fuel Economy City 6 34 mpg 6.9176 l/100km
Fuel Economy Hwy 6 53 mpg 4.4377 l/100km
Gear Ratio (overall)
1st 9.311 9.311
2nd 6.454 6.454
3rd 4.793 4.793
4th 3.882 3.882
5th 3.307 3.307
6th 2.79 2.79
WHEELS/TIRES
Wheels
Front 7 Silver, Solid Disc Cast Aluminum
Rear 7 Silver, Slotted Disc Cast Aluminum
Tire Size
Front 130/90B16 67H 130/90B16 67H
Rear 180/70B16 77H 180/70B16 77H
ELECTRICAL
Instruments Tank-mounted electronic speedometer with odometer,
time-of-day clock on odometer,
dual tripmeter,
fuel gauge with low fuel warning light and countdown feature,
low oil pressure indicator light,
engine diagnostics readout,
LED indicator lights,
6-speed indicator light
Indicator Lamps 8 High beam, directional light bar, neutral, low oil pressure, engine diagnostics,
turn signals, security system(optional), 6-speed, low fuel warnings
Reverse Function N/A
CHASSIS
Brakes 4-piston fixed front, and 2-piston torque-free floating rear
Parking Brake N/A
Lean Angle 30 / 31 °
Exhaust System Chrome, "Tommy Gun" 2-1-2 collector exhaust with dual mufflers
- Owners Manual
- Parts Manuals.
Engine:
Engine Type V Twin
Cylinders 2
Cooling Air
Valves 4
Starter Electric
Fuel Type Gas
Transmission:
Number Of Speeds 6
Primary Drive Belt
Wheels & Tires:
Brakes:
FXDF Fat Bob®
DIMENSIONS
Seat Height
Luggage Capacity
POWERTRAIN
Fuel Economy
1st 9.311 9.311
2nd 6.454 6.454
3rd 4.793 4.793
4th 3.882 3.882
5th 3.307 3.307
6th 2.79 2.79
WHEELS/TIRES
Wheels
Tire Size
ELECTRICAL
dual tripmeter,
CHASSIS
Parking Brake N/A
