Like the title says. I'm looking at some 2008 wheels for my 2002 LX. They are 18". I won't need spacers or anything right?
Yes they will fit. Might have an issue with the caps not fitting unless you use a spacer though. There's many threads on this, be sure to use the search function.
Depends the cap. Some shallow caps won't clear without an actual hole (or clear at all). Some it is just required to trim the fins on the back of the cap and/or flattening the grease cap with a hammer.I searched and some mentioned trimming the center caps. Does that mean I would have to cut a hole or just trim?
I put them on and didn't like the results. It took away from the original esthetics of the vehicle. I left it OG except for blacking out the center caps.
