2008, RHD Land Cruiser 200's Head Unit
The Caribbean
Good day,
Just received a fully loaded RHD 2008 Land Cruiser, one that was made for the Japanese market, so obviously the entertainment head unit's functions/OSD are in Japanese (attached)..
Would any one know if there is a way or a CD that can convert this head unit display from Japanese to English?
Otherwise, do you think that by simply changing/plugging an equivalent English Head Unit (one from the UK for example..) would work/display correctly all the functions (Audio, Radio, DVD, TV, A/C, Surroundings Monitoring Cameras, Parking Assist, Cell Phone integration....) ?
The actual navigation part (Maps, Directions...) of the system is not important to me, what I'm looking for is the rest of the controls to be displayed in English
Any and all inputs, suggestions or ideas would be appreciated.
Kind regards,
Gosh, I don't know if a simple DVD swap would work....let us know how it works out!
Hi,
I'm from St. Lucia, in the Caribbean, but would appreciate a UK contact
you may also be able to change it through display settings. If you could read your way through Japanese to find where it is.
Thanks, but its strictly in Japanese
That looks exactly the same as the Austrlian display in the "Sahara" model.
If so from memory ( I am overseas on Holiday) the RHS buttons are from the top
Map
Destination input
?Menu - Config
? Phone set up etc
Audio video display
There is also a climate control there next to the auto button on the right below the display
There should be a DVD disc reader for the program in the glove box.
take a look at www.toyota.com.au
is it the same as the US version just the opposite side?
Map
Destination input
?Menu - Config
? Phone set up etc
Audio video display
Hi Boobook,
I'm able to use most of the functions, some are in English too, learning Japanese would be the most economical solution:)
Thanks..
Hi Boobook,
Thanks..
Good luck with that!
if you remove the head unit, please post pics!!
If all else fails and you want to get a different unit in your native tongue there was someone from Israel ("Moti", I believe was his name) that had obtained a bezel type of stuff (factory Toyota) which would allow you to install an aftermarket head/nav. unit.
But I would think that it's probably a simple programming that just needs to be performed to change into English. But what do I know?
Translation
Good day,
Kind regards,
Thanks for information
We are also seaching for Japanese to english translation will it help you for me.
email rafiwestern@yahoo.com
I have land cruiser 2008. The problem is head unit can't turn on and the air conditioner can't turn on.
Please tell me the problen and how to get the solution :)
The JDM radios like the (AX / ZX) will not convert to English. Also you might not be able to actually tune into most of the radio stations as in Japan they tend to use radio channels different then most of the world.
