Hello Everyone,
My first post, I've been lurking and reading. Finally bought a Land Cruiser this weekend. Its a 2007 LC with 134k miles.
I have an issue that I found this weekend. I actually noticed it when I bought it but I assumed I just didn't know what I was doing.
The truck automatically retracts the tilt column back and up when you remove the key however when you re-insert it it does not go back to the position it had been adjusted to. It does come back down but to some unknown (higher) location. I've looked through the owners manual and it reads that the column should return to the previous position. Mine does not and since I'm short I have to manually put it back into a drivable position. This is going to get old real quick if I have to do this every time I get in the truck. using the manual (switch) adjustments I don't hear any weird noises and the motor seems to run just as it should. Other than not returning to its previous position it seems to be operating normally.
Am I doing something wrong here? I do not believe I have any memory presets it should just work as the manual states. I did some searching but it mostly lead me to motor failures. I didn't see anything about this issue I am having.
I'd also be happy to disable this feature in the long run. I currently own a Tactrix cable for my Subaru. Would then my best bet be Techstream?
Thanks
Thanks
