For Sale 2007 DODGE RAM 2500HD QUAD CAB SLT 4X4 5.9 liter CUMMINS TURBO DIESEL $16,900 232k MI
JUST REDUCED TO: $15,900.00
Check out this Craigslist ad, located in Charleston, SC.
http://charleston.craigslist.org/cto/4266712121.html
LAST OF 5.9 LITER CUMMINS 24-VALVE I6!!! All Dodge Rams Diesels from 2007.5-on have the new 6.7 with Diesel Particulate Filters (DPF) and Urea Injection. 2007 Dodge Ram 2500 Quad Cab SLT 4x4 "LONE STAR EDITION" in Bright Silver Exterior with Medium Slate Gray Cloth Interior Clear South Carolina Title, though originally a Texas titled truck. 232,853+ miles on the odometer and running strong with cold AC! Bone Stock Truck - Only Performance Modification is EFI Live "Economy2" tune. I am the second owner of this truck and have logged very few miles myself. This really is an outstanding work truck with brand new Cooper Discoverer A/T3 LT265 70 17E tires. This truck may have some miles, dings/dents, but NO accidents and it's ready to work! I am selling because I no longer need a 3/4-ton truck, and want to downsize. Dents on rear cab roof are from low-hanging tree limbs on a job site, and are only cosmetic imperfections. I do have a lien to satisfy, but will ensure that South Carolina Title is delivered as soon as possible after full payment. Truck is still being driven occasionally, so miles may be somewhat higher at date/time of sale. Add Ons: -NEW Black WeatherTech Floor Liners Front & Rear -CAMLOCKER (crossover) Tool Box -TrailFX Nerf Bar -EFI Live "Economy2" tune from Anarchy Diesel See recent maintenance and build sheet from Dodge Ram (Chrysler Group) below: NEXT OIL CHANGE: 237,795 NEXT FUEL FILTER: 238,410 NEXT TIRE ROTATION: 233,403 NEXT AIR FILTER: 242,795 Motor Oil: 12 quarts Mobil 1 Turbo Diesel Truck 5W-40 Full Synthetic Oil Filter: MOBIL 1 M1403 Air Filter: WIX 49946 (4" pleat) Fuel Filter: Baldwin PF7977, Donaldson P551315 Transmission Fluid: 17.5 quarts AMSOIL ATFQT or OTFQT Transmission Fluid Filter: WIX 58613 Transfer Case Fluid: 4 pints AMSOIL ATFQT or OTFQT Rear Differential: 8.9 pints 75W-90 Front Differential: 4.6 pints 75W-90 Tires: LT265 70 17 "E"-range MAINTENANCE PERFORMED: NEXT OIL/FILTER CHANGE: 242,795 NEXT FUEL FILTER: 243,410 NEXT TIRE ROTATION: 233,403 NEXT AIR FILTER: 262,405 NEXT TRANSMISSION FLUID/FILTER CHANGE: 262,551 NEXT GEAR OIL CHANGE: 333,369 MAINTENANCE PERFORMED: 10AUG13 227,795 -Replaced Right-Rear Brake/Turn light bulb. -Installed front and rear WeatherTech Floor Mats. -Changed oil with 3 gal Mobil 1 Turbo Diesel Truck 5w40 full synthetic. Replaced oil filter with Mobil 1 M1-403 Extended Performance. 17AUG13 228,403 -Mounted/Balanced 4 new Cooper Discoverer A/T3 "E" range LT265 70 17 tires with Nitrogen fill (also Nitrogen fill in Spare). (Hay Tire Company (843) 556-8473) -Installed replacement Driver's Side Fog Light Trim piece. 18AUG13 228,410 -Replaced Fuel Filter with Baldwin PF7977 11OCT13 230,484 -Installed replacement Passenger's Side Fog Light Trim piece. 12DEC13 231,910 -Cleaned battery terminals and connectors. Charged both batteries. 17DEC13 232,134 -Replaced worn-out Hood Gas Charged Lift Supports with 2 new STRONGARM 4364 Gas Charged Lift Supports. 17DEC13 232,154 -Installed EFILive AutoCal Lite Anarchy Diesel custom "ECONOMY2" to improve fuel economy. 21DEC13 232,309 -Added zMAX Micro-Lubricant Transmission Formula to transmission. 26DEC13 232,369 -Changed Rear Differential Gear Oil with approx. 3.5 quarts AMSOIL Severe Gear 75w90 fully synthetic gear oil. Old gear oil looked good, with no metal or debris. Inspected Front Diff. and no issues noted. -Added 12oz zMAX Engine Micro-Lubricant to engine oil. 27DEC13 232,405 -Replaced Air Filter with new WIX 49946, and reset Filter Minder. -Bled Fuel Filter Water Drain. 28DEC13 232,448 -Changed Rear Differential Gear Oil with approx. 2.5 quarts Royal Purple 75w90 (0.4 quarts AMSOIL Severe Gear 75w90 fully synthetic gear oil). Old gear oil looked good, with no metal or debris. Inspected Front Diff. and no issues noted. 30DEC13 232,478 -Added 12oz zMAX Fuel Formula to 1/4 tank of fuel. 03JAN14 232,551 -Changed Transmission Fluid with 6.5qts NAPA ATF+4, and Transmission Filter with MOPAR 52118789. Inspected and cleaned pan and valve body as well as filter; everything within normal limits. -Added 6oz zMAX Transmission Formula. -Changed Transfer Case fluid with approx. 2.5qts NAPA ATF+4. VIN 1D7KS28C77J555907 Vehicle Description DODGE RAM SLT 4X4 2500 QUAD CAB PICKUP Model Year 2007 Body Model DH 7 H 41 Color PS2- Bright Silver Metallic Clear Coat ISD 02/28/2007 Sales Code Description *M9 Cloth 40/20/40 Prem Bench Seat -D5 Med Slate Gray ADB Protection Group AHCP Trailer Tow Group AL1 Quad Cab Lone Star Value Group APAS Monotone Paint BAZS 136 Amp Alternator BCQP 750 Amp Maintenance Free Battery BRTS Anti-Lock 4-Wheel Disc Brakes CBEP 40/20/40 Split Bench Seat CGDS Front Height Adjust Shoulder Belts CG1S Next Gen Multistage Front Air Bags** CKES Floor Covering Carpet CLE Front & Rear Floor Mats CSPS Passenger Assist Handle CSXP Rear 60/40 Split Folding Seat CUES Rear Underseat Compartment Storage CUSS Overhead Console w/Trip Computer CVHP Front Center Seat Cushion Storage CVN Folding Flat Load Floor Storage DGBS All 4-Speed Automatic Transmissions DG8 4-Spd. Automatic 48RE Transmission DH3 Elec Shift-on-the-Fly Transfer Case DJQS 5,200# Front Axle DMES 3.73 Rear Axle Ratio DRQP 11.50 Rear Axle DSA Anti-Spin Differential Rear Axle ETH 5.9L I6 HO Cummins TD Engine GACS Tinted Glass Windows GFE Rear Power Sliding Window GNAS Rear View Day/Night Mirror GNMS Passenger Side Sun Visor w/Mirror GPG Power Black Trailer Tow Mirrors GVBC All Vehicles W/Power Mirrors GXMS Remote Keyless Entry GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation JAYS Instrument Cluster w/Tach JBYS Instr. Panel Color Keyed Bezel JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet JKYS Power Accessory Delay JPBS Power Locks JPDS Power Windows, Driver One-Touch JRDP Power Driver Seat JTHP Power 6-Way Driver Seat K1XP Jet Black - Molding - Bodyside K17P Bodyside Molding LMAS Halogen Headlamps LNJP Fog Lamps LPES Cargo Lamp MBFS Bright Rear Bumper MCMS Body Color Upper Fascia MCTS Bright Front Bumper MDAS Front License Plate Bracket MFDS Bright Grille MGAS Ram's Head Badge MHAS Black Windshield Moldings MTDS SLT Badge MUSS 4X4 Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam MYGP Lonestar Badge NAA Federal Emissions NFUS 34 Gallon Fuel Tank NHBP Auxiliary Transmission Oil Cooler NHMS Speed Control NHNP Electronically Controlled Throttle NMCS Heavy Duty Engine Cooling NZCP Current Generation Eng Controller PS2 Bright Silver Metallic Clear Coat QS2S Bright Silver Metallic Clear Coat RAAC All Radio Equipped Vehicles RCDS 4 Speakers RDDP Fixed Long Mast Antenna REFS AM/FM Compact Disc Radio RSAP Sirius Satellite Radio SBES Power Steering SCVP Leather Wrapped Steering Wheel SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch TT5 LT265/70R17E OWL On/Off Rd Tires TZGP BF Goodrich Brand Tires WF1S 17" Steel Spare Wheel WGDP 17X8.0 Forged Aluminum Wheels WLZC All Aluminum Wheels WMJP Center Hub XA8S Non Adjustable Pedals XBSS Pickup Box XEAP Tow Hooks XEFP Transfer Case Skid Plate Shield XFHP Class IV Receiver Hitch XFKP 7 Pin Wiring Harness XFUS Trailer Tow w/4-Pin Connector Wiring XGWP Stain Repel Seat Fabric X97P 1-Year Service Provided by SIRIUS YAAS Build To U.S. Mkt. Specifications
Nice truck!! Can't go wrong with a Cummins.
Thanks, it is a GREAT engine, just more than I need right now. Hoping I can sell her and get in an Avalanche and maybe pick-up an FJ40 to work on.
