For Sale 2005 JEEP GRAND CHEROKEE LAREDO (WK) 4WD 3.7 liter V-6 NAG1 170,490 MILES $4,500.00 OBO
Listing this for my mother-in-law who is selling her 2005 JEEP GRAND CHEROKEE LAREDO 4WD 3.7 liter V-6 with 5-Speed NAG1 Automatic transmission. White exterior color with gray cloth interior that shows its age.
$3,600.00 located in Charleston, SC
GREAT SUV/GREAT RIDE!!! One owner vehicle, adult owned and operated. Clean and clear title in-hand. Runs and drives well with cold AC.
Vehicle is still being driven on occasion, so mileage will be somewhat higher at date of purchase. 170,940 miles on the odometer as of March 24th.
Recently Serviced at Rick Hendrick Jeep
of North Charleston. Extensive maintenance and repair records in-hand:
27OCT14 155,544
-Front/Rear Rotors and Brake Pads replaced.
(Pit Stop - Summerville)
04JAN15 158,778
-Replaced Rear Hatch Shocks with 2 STRONGARM 6104 46104SAP.
-Replaced right-side mirror with K Source G212 265R.
-Replaced Key FOB Battery with Energizer CR2032 3V.
09JAN15 158,792
-Replaced Air Filter with Purolator PureOne PA35414.
-Replaced Hood Shock, and both Glass Hatch Shocks with STRONGARM.
-Added 12oz 134a Refrigerant to AC.
-Added 6-Cylinder Engine Restorer to engine oil.
-Filled all 5 tires to 33 psi.
17JAN15 159,137
-Changed Transmission Fluid with 4 quarts SuperTech ATF +4. Replaced ATF Filter with Pro-King FK-326
-Changed Front and Rear Differential Gear Oil with SuperTech 75w140 Synthetic Gear Oil. Inspected Rear Differential; within normal limits.
-Changed Transfer Case Fluid with SuperTech ATF +4. Replaced stripped fill plug with 1/2" plug.
-Changed Oil and Oil Filter with SuperTech 5w30 Synthetic and Mobil 1 Extended Performance M1-209.
-Rotated Tires: rears-to-front and Front crossed-to-rears.
-Flushed Brake Fluid with AMSOIL Synthetic DOT 3.
-Noted bubbling at low-side AC port.
18JAN15 159,137
-Added AMSOIL Universal Synthetic Power Steering Fluid.
-Replaced Windshield Wiper Blades with 21" SuperTech.
-Topped-Off Prestone All Makes All Models Any Color Antifreeze/Coolant.
15FEB15 160,480
-Replaced PCV Valve with BWD PCV502.
-Replaced all Spark Plugs with NGK ZFR6FIX-11 6441 Iridium IX.
-Replaced HVAC Control Lights with 3 x EiKO 2162.
16MAR15 161,679
-Oil Sending Unit Replaced.
-Quart of Engine Oil added.
23FEB16 170,799
-23 Point Inspection.
-Ignition Switch Recall.
-Replaced Starter and Starter Wiring with MOPAR 08052004 Starter, MOPAR 08015002 Wiring.
-Replaced Battery with MOPAR 01883001.
(Hendrick Jeep Chrysler Dodge Ram Fiat Alfa-Romeo North Charleston)
14MAR16 170,806
-Clock Spring replaced with MOPAR 08035035.
-Lamp Switch replaced with MOPAR 08050082.
-Rear Ring Gear whine still audible and confirmed by Production Manager, Tom Rydelek.
16MAR16 170,864
-Increased Tire Pressure in all 5 tires to 42 psi for better fuel economy.
24MAR16 170,938
-Added bottle of Sea Foam to tank when fueling with 87 Octane E10 from Shell.
*Minor scratches, dents, and blemishes consistent with an SUV of this age
*Stained upholstery with minor damage to driver's seat cushion/cover.
*Driveline "hum" under acceleration most likely indicating worn ring and pinion in rear differential.
*TPMS light comes on rarely likely due to age of TPMS sensors; tire pressure is stable.
*Tires have approximately 30% wear remaining.
*Small chip in windshield.
NO WARRANTY IS EXPRESSED OR IMPLIED BY SELLER. SALE WILL BE FINAL.
